^what William said. An FMU will work or you can use a BPT ECM. They are fairly common and have come down in price since people started using megasquirt or the new option from BP specialties. Still plenty of potential to rip the treads off your blizzaks though, lol.
Power Commender III
Originally posted by william View PostYou said you have a adapter plate for the bp to g series? It's bolt up no plate needed.
As for low boost 12.1 fmu.
I don't have much knowledge with boosted engines but someone can help here I'm sure.
Sent from my XT1585 using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Originally posted by Advancedynamix View PostIn order to have a happy and reliable B series engine that is regularly pushed over 8k, you'll need to do a lot more than lighten and balance a few things. These engines aren't designed for that. They are harmonically unstable above 6500rpm. An ATI damper does wonders and there are a few internal tricks that we have had luck with.
You definitely don't want to build a high rpm BP. They are a great mid range engine, but running them past 7200 is a recipe for trouble.
The zl-de (jdm 1.5 dohc) is a better choice from what I can tell. I've got one that I need to tear into in order to see what I'm working with. It's got the same bore as the b6, but a shorter stroke. This is a step in the right direction for stability at higher revs.
As far as I know, you can't just wire a power commander into anything, it doesn't work like that. It's a device that piggybacks the factory ECU and fools it into being tunable. It is specific to the ecu it was meant for. I don't know if there is enough tunability with a power commander to tune a 600 system to run an 1800 engine with a drastically different TQ curve. I'm not going to tell you that it's impossible (I've seen crazier things happen) but it's very far fetched.
If you have a BP and a g15mr already then put it in and enjoy it stock. You'll have a blast. Put a simple turbo on it and make 220hp and enjoy having a better power to weight ratio than almost every car on the road while still being able to carry lots of crap in the back and park in any spot you find.
A wide TQ curve with extremely high Rev limit is what these cars need to be unbeatable at the track. Heck, I could have passed way more cars in Tweak with an 8k rpm peak. But, for the street or autocross 6200 is just fine if your gearing and tire size is correct.1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
19?? 150$ burnout car SOLD
1991 (STRESS RELIEF)SOLD
Originally posted by Advancedynamix View Post^what William said. An FMU will work or you can use a BPT ECM. They are fairly common and have come down in price since people started using megasquirt or the new option from BP specialties. Still plenty of potential to rip the treads off your blizzaks though, lol.
93 L find/5 speed
BP/g15mr swapped
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
Originally posted by mikemounlio View PostSorry to thread jack but i would love to (like my list will ever end) set up one of my b6t's to have super high revs. Advancedynamix any chance you could PM me some ideas or thoughts? I might need more rpm in Lucifer.Last edited by Advancedynamix; 07-12-2016, 08:12 PM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
You the MAN1990 (LUCIFER 2.0) fully built BP+T with E153, Fueltech FT500, traction control with hopes of 600hp (i drank to much of the KOOL-AID)
Yes I was a bit too general in my previous statement, my apologies. Reciprocating tensile strength comes into play as well as air flow management, harmonics (as stated by Charlie), rotating mass and balance, fuel control, bearing, thrust, ring, spring, and piston rock tolerance, etc. etc. etc.Trees aren't kind to me...
And side fumbling of the lunar wing shaft Arty, can't forget that!Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
The proper tuning of the turbo encabulator is essential.Trees aren't kind to me...
Yes, and it should be calibrated using test TE-10 from the service manual/songbookDriving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
Any wobbling or grinding noise should be considered normal.Trees aren't kind to me...
Where do you place the flux capacitor for maximum flux capacitance?Any difference that makes no difference is no difference.
