I'm getting some hard shifting going with this very hot weather on-  and ready to check level and change the gear oil.  Never been done to my knowledge and never any problems before.
I see syncro rebuild kits at vendors with brass or copper? syncro rings I've heard mentioned in other threads searched here, and a couple of other bearings and seals.
My question is, f it comes down to a replacement of the syncros- which I can definitely NOT do myself,
how much of a repair is it? Can a good qualified shop do this or should I head right for a transmission shop?
Also- how cost effective would t be to replace the clutch kit pressure plate assembly then? Does a tear down involve the clutch assembly or is that a completely unrelated deal?
What other bearings or assembles might be involved if it gets into a syncro repar?
Car is a clean Aspire 5 speed manual transmission, w/ 120,000 miles
any info or advice appreciated. Thanks!
