Gas guzzling for a festiva anyway
  • Gas guzzling for a festiva anyway
    So I filled up last night drove the half mile home and dis my usual this morning drove a total of 21 miles I stopped at the same gas station today and used 1.2 gallons..... Oh boy now granted the engine isn't perfect it has an bad oil burning problem when it's cold but that's oh well any help? My prc vacuum solenoid broke so the fuel regulator is running on manifold vacuum is that the problem?
    Sent from my XT1585 using Tapatalk
    Festiver
    93 L find/5 speed
    BP/g15mr swapped
    Aspire brake swapped
    stripped and sold due to rust
    89 festie
    rustful
    93 festie
    advanced suspension
    kai/skeeter camber
    b3t/g15mr
    The FPR should always see manifold vacuum, so that's not it. Pull and inspect your plugs and check the voltage coming out of the o2 sensor (engine to temp and running).
    Also, 21 miles is too small of a sample to verify such crappy milage.
      Ok I'll check the o2 you could smell the gas in the exhaust so I adjusted my vaf 3 clicks leaner till the exhaust wasn't fuel filled doesn't really run any different power or band wise also is it normal to have b3 like horsepower till 3500 rpm then it seems to rocket off has plenty of torque at any rpm but the hp isn't really there at the low end
      Festiver
      93 L find/5 speed
      BP/g15mr swapped
      89 festie
      rustful
      93 festie
      advanced suspension
      kai/skeeter camber
      b3t/g15mr
        There is no such thing as low rpm HP, as HP is a function of force (torque)/time.
        Given that, what engine are you running?
          Timing being off will do that.
            Running a 94 protege bp
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
              Ignition timing or cam timing?
              Festiver
              93 L find/5 speed
              BP/g15mr swapped
              89 festie
              rustful
              93 festie
              advanced suspension
              kai/skeeter camber
              b3t/g15mr
                ^ either.
                Verify mechanical timing first, then ignition.
                  ^ either.
                  Ok thank you I'll double check my cam timing today
                  Festiver
                  93 L find/5 speed
                  BP/g15mr swapped
                  89 festie
                  rustful
                  93 festie
                  advanced suspension
                  kai/skeeter camber
                  b3t/g15mr
                    21 miles really isn't enough to get an accurate mpg reading unless under scientific conditions. I would suggest at least a whole tank, but I would consider at minimum 3 tank fulls to get an average.
                    Rick
                    1993 Ford Festiva
                    2000 Ford E350
                      Oh ok I'll see what it's like going to madness but I did 100 miles and used 4.5 gal 22 mpg I'm gonna lean it out a bit more check my timing and my o2
                      Festiver
                      93 L find/5 speed
                      BP/g15mr swapped
                      89 festie
                      rustful
                      93 festie
                      advanced suspension
                      kai/skeeter camber
                      b3t/g15mr
                        Ok update my vaf and afr were spot on .3-.5 volt readings from the o2 so I don't really know I'm not a crazy driver but I'll try driving more grandma like and see if that helps lol
                        Festiver
                        93 L find/5 speed
                        BP/g15mr swapped
                        89 festie
                        rustful
                        93 festie
                        advanced suspension
                        kai/skeeter camber
                        b3t/g15mr
                          Make sure your FPR is seeing vacuum
                            Yep it is
                            Festiver
                            93 L find/5 speed
                            BP/g15mr swapped
                            89 festie
                            rustful
                            93 festie
                            advanced suspension
                            kai/skeeter camber
                            b3t/g15mr
                              Also I gave a cel is there when a way to check I don't see a port anywhere
                              Festiver
                              93 L find/5 speed
                              BP/g15mr swapped
                              89 festie
                              rustful
                              93 festie
                              advanced suspension
                              kai/skeeter camber
                              b3t/g15mr
