Anyone Used T28 flange on stock b6t manifold.
  • Anyone Used T28 flange on stock b6t manifold.
    Looking for pictures if anyone has every purchased the T28 flange adapter.
    It'll work but it puts the turbo really low and makes it really hard to properly route the oil drain.
    Better Than Nothing Racing
    Way too many cars
    :woc:
      I have it now
      19?? 150$ burnout car SOLD
      1991 (STRESS RELIEF)SOLD
        My turbo is low. I had to getto the oil return. Its working but it looks ugly and has a good chance to come apart. The flange is ok. I would use it again if i had to but would look at not using it if i could.
          Can i please see pictures??
            i would like to see a picture aswell. Couldnta couple of nice AN fittings solve that problem?
              I'll try to remember to take pictures of mine tomorrow. The problem is getting enough angle on the drain for it to flow properly. The turbo fitting is only a inch or 2 above the pan fitting.
              Way too many cars
              :woc:
                An fittings almost make it harder since they're usually pretty long.
                It looks like a lot of room. But once you add in the oil drain flange and your fittings it gets tight fast. Also this is with a t25 flange welded on the manifold. The bolt on adapter may be thicker than what I have. This is with just a gt2554. A bigger turbo will probably bring it down further also.
                Way too many cars
                :woc:
                  My bolt on adapter is 1/2" thick. My oil return is crap FYI! I can and will make a better oil return line at some point soon. I have not gotten a picture yet i forgot.
                    i mean it needs gradient but with 2 45 degree AN fittings should be ok no? how does it fit by the water neck
                      My water lines were all re-done. Not stock anymore.
                        It's going to be pretty tight even with an fittings. For the water outlet I had to cut up a b3 outlet and reweld it so missed everything.
                        Way too many cars
                        :woc:
                          For my coolant lines i bought an elbow that bolted to my turbo. I then picked a coolant line and added a t pipe onto it. That pipe runs up to the elbow. same thing with the coolant return t pipe. heater hose to elbow on turbo.
                          Might be the wrong way or just a bad way but mine worked.
                            As far as oil goes i bought a steel an kit off ebay. I then had to get an inline reducer to limit the psi the turbo would see. Again all seems well there. The kit i got was way to long. but it seems to work just fine.
