the numbers stamped on the crank main bearing is FA130 Y8J it's a NDC bearing off of a DOHC BP thanks
can anybody decode the numbers on the main crank bearings to size of the bearing???
It doesn't show up on their catalog.
Are you wondering if the bearings are undersized?Trees aren't kind to me...
It is beyond unlikely that the mains have been turned down on the bp seeing as the bearing manufacturer you listed is what would have been used for initial assembly... Aka, a factory bearing.Trees aren't kind to me...
The bearing size is determined by the journal diameter. If you have a mic, take an ID measurement of the main bore and an ID measurement of the journal, and subtract ~ .003 then decide the sum in half, that's the bearing thickness. There should be ~ .003 difference the ID of the bearing and the journal. Measure the bearing installed and torqued.Trees aren't kind to me...
YesTrees aren't kind to me...
My pleasure. If you have any questions, don't hesitate to ask.Trees aren't kind to me...
