Hey guys, I poked around the forum a bit looking for where to get a better clutch, but it seems like any time someone even mutters the words "B3" and "upgrade" in the same sentence everyone immediately tells them to swap. I'm not looking to get much out of this engine, I'm just wondering if anyone knows where to get a lighter/stronger/better flywheel, clutch, and pressure plate. I'm not doing launches on the 1320, just looking for a little more fun in the canyons. Thanks guys
B3 Clutch Upgrade?
B3 Clutch Upgrade?
A mechanic knows how; A technician knows why.
Wrecked. Repairs in Progress"Frankie" 1957 Chevrolet 3100, NA 2bbl 283cuin, Muncy Granny 4sp, 3.90 Open Diff @ ~95K miles
Wrecked. Repairs in Progress"Alice" 1991 Ford Festiva L, NA EFI B3, 5sp @150k miles
Reassembling"Aurora" 1991 Ford Festiva L, NA EFI B3, 5sp @240k miles
FB Festiva page: Jared Bennett
Instagram: jaredbear82 -
Sounds to me like you need to keep the Festiva flywheel and up grade the clutch and pressure plate to an Exedy kit that you can find on E-bay for around $118.00 Good luckAn idea can turn to dust or magic, depending on the talent that rubs against it.
Wut he sed. You don't need more clutch with a stock B3, a SOHC B6, or even a B6D if you're not launching it.Originally posted by sc72 View PostSounds to me like you need to keep the Festiva flywheel and up grade the clutch and pressure plate to an Exedy kit that you can find on E-bay for around $118.00 Good luck90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Is yours slipping now? If you need to replace it probably an exedy and get your flywheel machined true again is what you need. Also check if the cause for slipping is the clutch actually worn or oil leaking onto it from valve cover gasket, distributor seal, crank seal or transmission input shaft seal.
It's not slipping, just starting to wear a little thin, high pedal engagement, so I figured when I replace it, why not upgrade? I wanted something lighter to reduce the engine's moment of inertia, but with as much or more tension on the pressure plate as the stock one so I can bang shifts quicker. Does Dickmeyer have a drilled flywheel? Or where can I get a light one?A mechanic knows how; A technician knows why.
Rock Auto has the Exedy Kit for $98, but it looks like it's just an OE replacement. Is there anything better about it?A mechanic knows how; A technician knows why.
I don't understand what you meanA mechanic knows how; A technician knows why.
You could get any racing clutch like this for example: http://www.ebay.com/itm/310321836974
I believe the reason no one else does is that a lighter flywheel and a grabby clutch will break your e-series transmission very quickly.
Besides which, there are a lot of people who are unhappy with the Spec clutches. Just go Exedy.Originally posted by ryanprins13 View PostYou could get any racing clutch like this for example: http://www.ebay.com/itm/310321836974
I believe the reason no one else does is that a lighter flywheel and a grabby clutch will break your e-series transmission very quickly.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The pressure plate clamping force is significantly higher than stock. And you can mill the flywheel down to about 10 lbs (16 stock), but I would go to 12 for longevity.Originally posted by Sid_RallyX_82 View PostRock Auto has the Exedy Kit for $98, but it looks like it's just an OE replacement. Is there anything better about it?Trees aren't kind to me...
Ok, I'm getting confused.
First, what do you mean by Quick Shifts? What I do doesn't feel very harsh for the drivetrain. I always try to be smooth when being quick
Second, how is a lighter flywheel bad for the trans? I would think it reduces shift shock because the shaft and crank can rev match easier...
Sorry for not being savvy and thank you for your experience and patienceA mechanic knows how; A technician knows why.
The flywheel weight has to do with harmonics and stored energy (lots of maths). True, lightening the flywheel will reduce it's polar moment, but it also reduces it's kenetic energy that's used for the up shifts.Trees aren't kind to me...
One of the main purposes of flywheel mass is to absorb resonant harmonic frequencies from the engine. The flywheel mass is calibrated to work with the engine. Changing that mass will change the harmonic cherictaristics of the flywheel and this usually results in more driveline failures.
I don't like the way cars with lightened flywheels shift. The flywheel mass makes upshifts feel notchy, and the cars become harder to match on downshifts because they are too touchy. Rev matching has 2 purposes. First, it makes gear engagement easier, but on a synchronized tranny this is less critical. Second (and of most importance in a ultra light FWD car) it adjusts the amount of engine braking that is applied when the clutch is released. The rate of clutch release is critical to adjust the amount of decel. I often use downshifts to set the front end in a corner, rather than braking, because I can pivot the car and then be in the sweet spot to power out. I need a nice smooth and predictable drive line to do this effectively. Lightened flywheels make this more tedious.
Rather than worrying about shifting fast, I'd be concerned with chassis setup that allows higher entry speeds, so less shifting is needed.
Edit: Arty posted basically the same info while I was writing that. LolLast edited by Advancedynamix; 01-31-2017, 08:42 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
