spacing crossmember down
  • spacing crossmember down
    when you guys are spacing your crossmember 3/8" down, are you spacing both front and back? or just one side?
    I spaced both front and rear of the cross member down as well as the passenger side mount bracket (because I didn't build any drop in when I modified the bracket). Engine not moved forward in this automatic swap.
    No car too fast !
      Yeah mine either. No room to move forward it seems.
      91GL BP/F3A with boost
        Why thank ya. Is there enough threads to use the original bolts? Or are longer substitutes needed?
          I dropped the front and back of mine a bit more than an inch with chunks of square tube. There is no question you need longer bolts.
          Icetiva-3-race-car-build
            Did you relocate the sway bar?
              In a way. I switched to an Aspire sway bar, which has a kink in it to pass over the cross member and back down again.
                Up to about 3/8" spacers the stock bolts have worked fine for me. I've done both ends or just one end depending on the engine/mounts.
                ~Nate
                Current cars:
                FOTY 2008 winner!
