Hi all I am looking to swap my B6T from a 1991 XR2 into a carbed 88 festiva. I need to know what to keep from the capri, axles? ecu? wiring? and so on and what will make my particular engine work on the 88 carbed platform. Thanks alot for any help.
B6T (XR2 engine & tranny) into 88 carbed.
Axles, wiring, engine, ECU, mounts, trans, motor=yes
also you will need a gas tank from a FI festy IIRC. Probally upgrade the pump at that time while its out.
Plus you will need to make all custom mounts to put it in the engine bay.
Poverty produces creativity
track car as in drag, autocross, ice racing, or circle track? A couple of people on here race their festy in competition so they probally would be a better source of info for a fuel cell. But heres my 2 cents.
As I said it depends on the application to determine if the cell is baffled/foam filled, capacity of the tank & location. Personally as long as you arn't doing an endurance race I would say get the 5-8 gal tanks. Face the ports to the rear so you can get gas during acceleration.
Its not that hard to swap the efi fuel tank,you also need to add a return line.
My car is a 88 b6t.
I had the whole tank go in the car,The difference is so little.its not hard @ all.I bet you are going to have a harder time swapping a fuel cell and its not necessary.My car is set up for your needs and it drives great.
