Originally posted by festivaWES
easy 2 minute floppy motor mount fix, its like a new car!
If I were to add an engine brace, I'd use some form of damper similar to a motorcycle steering damper braced to the centre of the engine, not a chain. Chains result in a sudden application of force when the slack is taken up to whatever structure you have the other end bolted to. That's probably what resulted in those bolts being pulled right out of the bosses.
A fluid of gas filled damper, by nature, transmits those forces much smoothly, although resulting in slightly more engine movement. Although the amount of engine movement could be controlled by the placement and travel of the damper you use.
It didn't work well enough to consider it worthwhile when I did it. It's because the two bottom mounts are supporting both the weight of the engine and the torsional forces from the engine putting power to the ground, whereas the transmission mounts on engines with 4 mounts (mounting setups with a weight supporting mount on both sides of the engine) typically only absorb those torsional forces. Because of this, these mounts have a different design that is easily improved with the urethane compound because they don't have to be stiff enough to support the +300lb engine/transmission to begin with, like the Festiva mounts.Originally posted by pole120Just curious....why not?
~Josh
Filling the passenger side mount will do nothing but add vibration because it doesn't support torsional forces, just some of the weight of the engine. Hope that answers your question.* Retired Festiva-er*
1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
B6T'ing since May 2002...
Disclaimer: I'm a dick, deal with it.
Well, i'm willing to look at two solutions to this problem....
I've got three oil filled engine dampers off of the SVT contour, i may take a look at fabbing some brackets to attatch on to the festy. However i'm also going to look into building poly mounts...i've built about 115 Poly contour mounts, however i understand the mount layout is/may be different so i'll ahve to look further into it.
~Josh
That's kind of a new one.
I've seen people attach one to the radiator mount, go all the way around the back of the engine and back to the radiator mount on the other side to hold it forward.www.dantheoilman.com
Go ahead and ask me why
