G series clutch fork bushings
  • G series clutch fork bushings
    So I let one of my transmissions sit for to long. The clutch fork shaft rusted a little and the bottom bushing froze to it. Of course my efforts to remove the shaft ended up damaging the bushing. It's no longer available from mazda or fourgreen so I'm going to need to get one made. Anyone know what material it should be made from and if a local machine shop would be able to do it?
    Lower
    Upper
    Dimensions
    Better Than Nothing Racing
    Way too many cars
    :woc:
    I second this, Mine are pretty shot
    Will Samet
    How to find me:
    Feel free to PM me anytime!
    Instagram/Twitter: @WILLSAMET
      Thinking the bushings from the ford escape or mazda tributes with g boxes might be worth looking into.
        They used a hydraulic clutch fork setup. This is only on the cable boxes.
        Way too many cars
        :woc:
          I have an open tranny i salvaged the shift linkage bar thing from, could it be worth taking a look at to see if i can send you a replacement? provided its not thrashed?
          Car #789
          Sponsors: Williams American Construction, Dewaynes Tire service, Roofing Supply Group
          1992 Festiva L - BP Swapped, Aspire Swapped, Rally America Sanctioned.
          1993 Festiva GL - 4sp Automatic and the bluest car i've ever seen...
          http://www.facebook.com/warally
            I'm a machinest and that's no prob to make you just need to find out what material it is made from
              Bronze would be my choice.
                Let me see how much it'll cost to get new ones made first. I'd rather not put 25yr old ish bushings back in.
                I thought so just wanted to be sure. The original ones are plastic. Just hope I can find a shop around here that will do it and not screw it up the first time.
                That's what I was thinking but didn't know if there was something better suited.
                Way too many cars
                :woc:
                  Bronze or nylon. Bronze will last infinitely longer then nylon.
