Lets say you have a parts festiva that the body is in good shape but everything else is junk and you have 3 drag tracks within 100miles of you. What motor and transaxle would you run in the car drag race only? I saw one on youtube a white festiva running 9s i think it was on junkyard parts.
Festiva drag car motor
Bpt big turbo and an e153
Actually i believe thats the exact set up for that car. Motors built out the ass.
Id like to see an auto puttin in work behind a bpt but oh wellCURRENT. Past
88 festiva L. 89 xr4ti
14 foST. 89 xr4ti
82 F100. 97 silverado
82 GS1000. 06 h3
82 GS750. 79 ta 6.6
74 TC185. 89 turbo katana 600
69 T500. 80 gs1000
15 sonic 82 cr480r
FB_IMG_1522887889165 by Brandon Hobock, on Flickr
FB_IMG_1522887851952 by Brandon Hobock, on Flickr
The manifold is worth more than my festy lol!
Made that power on 50psi through a precision 64-66
Actually that car is only an hour from me, i want to see it in personCURRENT. Past
14 foST. 89 xr4ti
82 GS1000. 06 h3
82 GS750. 79 ta 6.6
69 T500. 80 gs1000
15 sonic 82 cr480r
I have a worked up automatic behind mine. I grenaded the diff though before I could go back to the track on higher boost.
Ran 13.7's on 8 psi. Was a lot of fun. Very fast shifts.
Years ago a guy in Canada was running 12's in an aspire with an automatic.91GL BP/F3A with boost
There is a bigger automatic transmission from the late 88-89 323 that is a hydraulic control version of the one used in bigger cars like the MX6/626/Probe. Its an overdrive too. It has been swapped into a festiva at least once, but that was with a stock engine. And it was never documented. It is quite large and would probably require some work to fit it with a BP and turbo stuff. But if I can work up the motivation I would like to try.Originally posted by Thebrandonbeezy View PostI wonder if somthing could be made to fit it ??91GL BP/F3A with boost
Not all of them have the overdrive trans. The only way would be a visual confirmation. It'll have an OD button on the shifter. I'm not positive but I think only the hatchback got it.
The non-overdrive transmission is the same as the festiva one.91GL BP/F3A with boost
