1.3 DOHC 1nstallation EEC wiring
  • 1.3 DOHC 1nstallation EEC wiring
    I got ahold of a 1.3 DOHC engine, manual trans, ECU and harness and other installation necessities a few years back. When I laid out the harness I had several connectors that I had no idea what they went to. Anyone know IF this thing will run okay on the B3 ECU,(I kind of doubt it) I found a distributor with the correct connector. A wiring diagram for a JDM spec 1.3 DOHC would be priceless. I have searched on the web with little/no luck. Until I did some searching on our forum I thought maybe I could mount that head on my short block, but It sounds like the valves would hit the block. Anyone done this swap, or with a link to wiring manuals/diagrams Thanks.
    186,000 miles per second is not just a good idea, it's the law
    1990 yellow L+ (l8ly)
    1990 yellow L+ (sunryz)
    1992 aqua L (agua)
    1993 blue L (aurora)
    I'll trade you for a 1.6 dohc. Seriously if you want to sell it ill buy it. Who imported it for you?
    No one has done that swap that I know of so it's never been documented. There is a member on here that has imported a gtx so he might be able to help you figure it out. That engine is such a unicorn it's probably better to use the jdm ecu and harness.
    Where at in va are you? I'm about 2.5 hrs from dc. I could run over and help you sort out the wiring.
    Sent from my SCH-I545 using Tapatalk
    Better Than Nothing Racing
    Way too many cars
    :woc:
      I know the 1.3 DOHC car had some options like a can cooler in the dash top and some suspension adjusting stuff as well. Maybe those weird connectors went to foreign options?
      Not much help, but I'd look up the GTX models and see what they had, just to get an idea.
      Karl
        Sent you a PM
        1992 aqua L (agua)
          My guess is since the GTX was an 80's model it has similar wiring to our 89 EFI and BF cars.
          91GL BP/F3A with boost
            Definitely seems like the engine to go megasquirt on or some sort of stand alone engine management
            Sent from my SM-N950U using Tapatalk
            Festiver
            93 L find/5 speed
            BP/g15mr swapped
            Aspire brake swapped
            stripped and sold due to rust
            89 festie
            rustful
            93 festie
            advanced suspension
            kai/skeeter camber
            b3t/g15mr
              Also look up "Festiva GTA." That's the aero nosed version. I think it ran a 1.3 DOHC.
              Karl
