Just to help people searching for this info I just did a b6me swap and couldn't find this stuff
B6me has the 16 valves and is found in the mx3
Parts I needed were:
-B6me Intake injectors ect and exhaust
-MANUAL b6me Throttle body I had the auto and it wont work so im currently using a BP throttle body
-The IAC, make sure to get the plug
-Manual B6ME computer
-The VAF and all the hoses and whatnot are very helpful.
-B6 Distributor, the festiva one is upside down or something
Parts you will need to modify/use:
-Bash in the firewall approximately 1.5 inches with a big ole hammer
-Modify the throttle cable bracket, just redrill the holes so it fits right, easy
-Replace the IAC connector with the b6me connector i have no idea if polarity matters i dont think it does
-Reuse the b3 injector harness, alternator brackets, engine mount, thermostat housing, fan switch and front temp sensor (the plugs are just different)
-Unravel the harness and move the VAF plug to the other side of the engine bay.
-You will need to either use the b6me downpipe and modify as needed or drill out the flange bolt holes on the festiva one and shorten it i recommend figuring out a whole new exhaust.
-You will also need a smaller battery
-make the brake booster hose longer
If you want to keep your ac you will have to use the festiva metal coolant lines the ones that go directly to the bottom of the radiator and you'll need the proper pulleys. Unfortunately I can't remember but i think the B6me uses a grooved belt and the b3 stuff is a vbelt. A 1993 b3 pulley should fit. There are a few different types so sort that out.
Typing this from memory let me know if i forgot anything. My check engine light is on so i probably did.
