Looking to put the power around 225 naturally aspirated and about 350 400 turbo charged anyone know where to get billet internals or some sort of performance internals and does anyone know how much power stock trans will hold up to as well as is there a way to bulletproof the manual 5sp
Does anyone know where to get performance internals
Your stock engine and trans will never be that powerful but you can swap to a BP with a G-Series Trans to get close to that. Check out some of the Engine Swap Threads for more details."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
Exactly what Firebrush said, this picture is an example....(not sure who's it is, think Charlie's), I want mine to be like this one day. The forums have amazing write ups and there are great people here you can ask questions to who will give it to you straight.
Sent from my HTC One M9 using Tapatalk
these guys have some good engine parts! thats where i got all my forged internals for my BP if your going that route.
So then nothing for the 1.3 i wanna build power but i still want semi decent fuel economy i wonder if i can get stuff cusgom made i want to shorten the stroke and widen the bore so i can make turn way more rpm like 12k but i wanna turbo with a bypass in place so i can go from grocery getter to full send with a switch so has anyone did a 1.6 swap like the new fiesta st engi e with a stage 3 cobb is around the 250 300 mark and i would be happy with that i just wanna stay as much ford as i can.( yes i know they are kia made lol but im in a ford vs chevy battle with my uncle paul he thinks that no amount of money will make my little festiva put out over 250 hp i have a 93 its kinda beat up but definitely solid
So currently the highest revving production car is an Ariel Atom at 10.6K using Hyabusa engines but you for some reason think that you can make an engine that was produced by the millions in the 90s hit 12K RPM more than once while also flipping a switch to run two very different fuel and timing maps on the fly?
To answer your question partially, there are custom camshafts that you can run but they are not easy to find. The specs are on the forum if you want to get one custom ground to match something that is already know to work. Also look up Matt Dickmyers B3 engine build to get a couple ideas on how much work it takes to get over 100HP out of the B3."The White Turd" 1993 Festiva 144k miles. (Winner of FOTM November 2016)
- Likes 1
I'm working on some more budget friendly b3t building ideas still tuning the car could very well just blow up not going to release much till I know it works or not
If you want to build big power on the cheap
Junkyard bp I have an extremely low milage (9k miles) one i might be interested in selling for the right price
Used turbo something around the gt3076r would get you 350 whp
G15mr trans from a 91-94 capri xr2 with corresponding axles and speedo cable
Festiva store bp gseries shaft adapter
Mike Mounlio BP g series mounts cheap but takes a while hes a busy guy
Kai injection 610cc injectors disty delete while you're at it I'd suggest the conrods too better safe than sorry and they're so cheap but high quality
Used megasquirt stand alone ECU or diyautotunes ms2 or microsquirt
Aluminum honda rad (needs modified)
Upgrade core support
Clearance driver frame rail for g series
Let er rip tater chip
Sent from my SM-N950U using TapatalkFestiver
93 L find/5 speed
BP/g15mr swapped
Aspire brake swapped
stripped and sold due to rust
89 festie
rustful
93 festie
advanced suspension
kai/skeeter camber
b3t/g15mr
The bottom end isn't the problem, it the head and trans, neither can support that kind of power, even with mods. B3 and B6 stroke is the same, there is a B series short stroke crank, but you'd have to import it ($$$).Trees aren't kind to me...
^^Or buy a car that already has one installed like someone here did over the weekend..~Nate
Current cars:
FOTY 2008 winner!
