Originally posted by Dave G
One cylinder would fire every 360 degrees, so it shouldn't run too rough.
It would be balanced if you removed the other 2 pistons & rods.
If you removed the other 2 Pistons/rods you could take off the rocker arms so the valves would stay closed.
Ok you might not want to completely remove the rocker arms due to oiling reasons, but you could cut off the cam tappet side so it wouldn't run on the cam.
Poverty produces creativity
