What goes first in the stock 5 speed when you up the power? Gears? The differential? Thanks for input.
Tranny weak link?
Tranny weak link?
1986 Comp Prep SVO Mustang(1 of 83) Four cylinder turbo! (Think first Fox body "R" model!)
1969 Ford F100 Big Block Ranger and it was free! (coming 2/12)Tags: None
Re: Tranny weak link?
Clutch then syncros if you powershift, failure from that point are hard to tell what went crunch next. Loose some teeth befor if froze up snapping the mainshaft, or shaft lock up causing teeth to sheer?Originally posted by KraigWhat goes first in the stock 5 speed when you up the power? Gears? The differential? Thanks for input.
It depends on what engine you have. You could kill a Festiva transmission with a B3 if you beat on it long enough. From my experience, the differential (spider gears) goes first, then the case cracks. After that, you'd probably strip gears, then snap gear shafts... some where in there, you may snap the axles... but I never had that happen to me.* Retired Festiva-er*
1990 Festiva - The Once Fastest Red 1990 Festiva LX on this site! - now in more dedicated hands!
B6T'ing since May 2002...
Disclaimer: I'm a dick, deal with it.
Huh. Never had diff gears go, or a case crack without plentyOriginally posted by B6TIt depends on what engine you have. You could kill a Festiva transmission with a B3 if you beat on it long enough. From my experience, the differential (spider gears) goes first, then the case cracks. After that, you'd probably strip gears, then snap gear shafts... some where in there, you may snap the axles... but I never had that happen to me.
of bits rattling around inside first.
