Can someone please step up and direct me towards a 205 that fits the aspire 1.3L engine? My car i bought used, very used heh and it has a BRAND NEW radiator and hoses so i think it can hang with this upgrade. It will make this car warm up and keep its heat. It doesnt get all that cold where i live (southern california) but as soon i am moving more than 20mph the needle is back low in the cold range. I think its costing me mileage and upping the emissions that I havent even tested yet. I plan on upgrading to a 4 wire oxygen sensor this week as well to try and beat emissions with the heated wire trick.
OEM is 192 degrees on my car. I want a 205
I understand the wanting to go warmer , but if it is cooling off that quick , it sounds like the thermostat is stuck open .
Even when it is real cold , like 9 above in the morning (Tue) here :lol:
My gauge will be slow to climb , but maintain on the gauge .
The car itself will get cooler inside , because of the un-insulated pop can effect :lol:------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
yeah i had a feeling it was stuck and now that i read more on this forum its a no-no to get the autozone thermostat part, and i should locate an oem mazda part. i hope they are open on this holiday. It IS actually cold here this week and last, i havent worn shorts since xmas =P1993 GL 5 speed
^^ I have done that before .
Z28 LS1 power 500 +
Mine did the same thing do to a stuck stat. I replaced mine with a b6t
 But a cheap honest fix is covering about 1/2 to a1/4 rad with cardboard. not rite but a cheap fix.
						"Look, I have long hair, tats and smoke like a chimney.. All of my customers know it.. Don't like it? Don't turn over my rock."
RIP DJ
"Cold" is relative... my wife and I were up at Emerald Lake about 45 minutes west of Banff, Alberta. When we left on Sunday morning it was -32°C (-26°F).Originally posted by getnpsiIt IS actually cold here this week and last, i havent worn shorts since xmas =P
Car started OK and warmed up fairly well too now that I have the proper thermostat in.Ian
my 95 aspire during the summer had no problems warming up, but come winter it would only warm up when sitting still, but when i went to moving it went back down to c lol replaced teh tstat about 3 weeks ago and what a diffrence lol, although my tstat i got at advance and it was the exact same that i pulled out,
now tell me if you can why some take a dual stage tstat please.2007 Ford Taurus 23-25MPG
1976 Chevy Silverado (my toy)
1951 Ford Deluxe, being rebuilt
Have an old car truck or tractor? Go here.
http://www.aintperfect.com/
My POS aspire won't warm up if I'm not moving. If I'm on the interstate it warms up fine, but the second I get off and slow down or come to a stop sign the gauge starts dropping.
Then again, it was neg 20 this week. But even when it's near zero it does that.www.dantheoilman.com
Go ahead and ask me why
I used an autozone replacement, no difference temp always reads 160 once it warms up
(IEQUUS electric gauge). takes about 10- 15 minutes to warm up on a cold day sitting
still.Nothing says "triumph of enthusiasm over physics" like a Front Wheel Drive race car.
- Dennis Grant
FarNorthRacing.com
Engine is dead. dying engines don't give a lot of heat heh. I've got a good lead on a 16 valve sohc. Im not sure about my obd-2 but ill cross that river when i get there.1993 GL 5 speed
