Limited slip??
  • #16
    I think I'm going to try a Phantom Grip when I install my G25MR. I mean what's the worse that can happen? I blow up a $50 transmission or it just doesn't work. :dunno
    In a few years I'll start looking for MSPs at the junkyard and adapt that one...
    • #17
      where do you get these springs your speeking of i found a good deal on a phantom that i cant pass up
      • #18
        phantom grip sells them on their site. i plan on getting one for my festiva once i get my b6 sohc back from the shop
        is not sposed ta do that...
        05 subaru legacy gt
        1991 nissan nx2000(almost awesome as a festiva, my first failed mtx)
        1988(?) festiva LX 5spd (rescued from crusher,aspire swap done, working on turbocharging the 1.3...)
        • #19
          i picked up the phantom grip todday it was instaled in a escort gt he gave me the diff he also welded the pins in it? i dont know if i should just use his diff or install it in the stock diff.
          • #20
            Well I've heard that if you remove the phantom grip out of a diff it never works the same. I would use the complete diff.
            • #21
              I have been using PG's for years and have successfully replaced the springs, once you pull the lock plates off after installation, make sure you don't lose them like I did. PG sent me new ones for a fee.
              The PG seems to work in slippery conditions.I did not think the thing worked at all until I put the stiffer springs in, then it almost felt like a welded diff. So ,went back to the stock ones for Ice racing...
              Ice Racing is Still a Black art!
              1989 B6 Twin Webber Stud racer (mine)
              1990 B3 Stock Auto racer Welded diff (daughters)
              1991 B3 Stock Rubber class racer (wifeys)
              1993 B6 mustang embarrassing road car (mine)
              1992 B3 Parts car
              Assorted 323's
              • #22
                Which springs?
                Hey Champ 98, Well do you feel there is a difference with the lsd on the ice or not? I'm only interested in the ice performance (not pavement). I was thinking about one for my car that I also Ice race here in Michigan (M.I.R.A.). I took a third place this season in fwd rubber to ice. The first place guy, a neon, hakka Q's, and some kind of an lsd, kept out pulling me. I was running a 90 festiva with a fuel injected b6, 5 speed, and 13" blizzaks. I just got a fresh 97 aspire that the b6 is going into for the 2008 season. I've also made up a turbo setup with a methanol injection system that I hope will give me a little more everything. Also did you put that lsd in yourself? If so, was it difficult?
                Although the festiva served me well, it's just rusting out from under me!
                p.s. I tried out some new hakka rsi's, but thought they were not as sticky as the blizzaks on the bare ice! We don't "Tractionize" our tire's here. Do you think that helps new Blizzaks or Hakka's?
                • #23
                  Wow $300 a bit pricey. We need write obx and talk them into making a diff.
                  "Look, I have long hair, tats and smoke like a chimney.. All of my customers know it.. Don't like it? Don't turn over my rock."
                  RIP DJ
                  • #24
                    300 isnt as bad as paying 1k for a lsd they have a link mazda323performance.com for some compony that makes them il se if i can find it.
                    heres the link i didnt think i was going to find it.
                    we need to merge with the other mazda groups theres so much info that could help us from the other boards
                    The definitive Mazda Owners Community & Resource. Covers CX SUVs, MX-5, Mazda3, SkyActiv & Rotaries. Discuss DIY maintenance, tuning, firmware updates & EV tech
                    • #25
                      Merge....NO
                      I'm on the FEOA/escort, 323, club protege, miata, mazda forums, probe/mx6 & a couple non-mazda forums. Yes the info is sometimes spread out, but if you know where to look you typically can find it. Each has their purpose. The protege, miata, & FEOA I reference engine data mainly. The probe, 323, & FEOA are for trans info's. All the above I look at for interior & exterior info.
