I just got my new B6D running, and I have some questions about setting the timing. I am using all festiva electronics, and distributor, with a 91 capri engine.
With a timing light, when I set the timing to a degree before TDC, the engine runs fine. When I advance the timing, it seems to idle smoother, all the way to ~20 degrees BTDC. The book states 2 degrees for the NA and 10 degrees for turbo. Should I set it to idle smooth, or should I set it to 2 degrees?
