Welding spider gears
  • Welding spider gears
    Has anyone tried it on a festiva?? I know it promotes premature tire wear and wear on the axels.....Has anyone took apart a trany to see if there's adequate room for welding??
    I don't know if that works on FWD. Might have trouble turning.
    93 GL modyfied!!!
    :fish:
      Many honda guys have done it in the past.....yeah about the handling issues, not a good idea
        Yes you can but if its not a track (drag) car dont do it. Turning will be very difficult & the tires will skip around the corner.
          I would not want to try it on a FWD vehicle .
          I have seen it done many times on a RWD car .
          You should hear my rear tires squall on the S-10, when I turn corners . 21.5 rubber and a full spool
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
            Weld
            You need an lsd, spools don't work on fwd cars.
            1996 Aspire, 2DR 5SPD 185 60 14, Aluminum rims, Mild Stereo system, some neon tubes, 185 000 km not a speck of rust runs like a champ
            B8-ME Swap COMPLETED.
              I don't think they make a spool for a FWD.
              I was just saying I have one in my truck.
              Z28 LS1 power 500 +
