stock festiva hp????
  • stock festiva hp????
    what is the stock hp of a festiva????
    i should know this
    ops: shayne
    63hp
    Is that a Festiva that just passed me?!?!?!
      FROM PROJECTMAZDA.COM
      Those who think drifting through life is easy, never tried it in an FWD.
        63 at the crank for a fuel injected car and 58 for a carbed car.
        The Festiva Store
          to quote with nonamekid, is true? that EFI festive has more HP compared to car festive?
            Yes, it's true. Those are the factory numbers for Ford Festivas.
            Karl
              carbs.... stock sux
              the carb festy has more potential than the EFI system if you can mate a larger carb to the manifold, though there is such a thing as too big, so i'd start looking for 2bbl carbs from older import trucks. As for myself, i'll be using a 4bbl Nikki carb off an RX-7 mated to a high flow B6. i'll post results as soon as i get dyno time
