FMS Cams
  • FMS Cams
    I did a little lookup and I couldn't find much on the FMS cams. I was wondering if anyone was running the Racing Cams. If so how are they. Do you recommend the Competition cams? I'm not really concerned about the "rough idle"
    88' Ford Festiva
    97' Chevy Silverado Z71
    94' Chevy S-10
    I have 1 in my b3 and Im very happy with the performance gains. I had installed it with stock compression, it made a small difference. Then I hade the head shaved to give it about 10.5 then you can really feel and hear a difference. When I put the cam in I also installed a set of the performance valve springs.
      be careful with those performance springs!!! i had the same setup as you and 3 months later i blew through 7 out of 8 lobes on the cam....
