sorry for the long post but i know to help me out you would need details.
So I was on ebay and found one of those intake adapters real cheap... so I bolted it with the gasket on the stock box to the VAF and bought a cone filter from autozone for 20 bucks, when I put it in, it was obviously too long. I knew I had to shorten the intake hose. So I went to Home Depot and bought a 2" to 2" sewer and drain hose rubber coupler fitted with 2 hose clamps.
I brought it home and fitted one end to the circular end of the VAF with some prying by a butter knife (works Great) and cut the intake hose with a sheetrock knife right after the first rib closest to the VAF. I put the other end of the coupler over the rubber hose and hose clamped it on...
I zip tied the VAF to the body and took her for a test drive. I noticed a greater throttle response... The sound afterwards was throaty. 5 minutes after I took off I noticed the engine revving more than usual so I brought it back home and checked it out.
It seemed to me like it was a vacuum problem in the intake... and the weakest link (sealing wise) was the rubber-to-rubber connection. So I went to Autozone again and got some ATV sealant and pulled the clamp off and pulled the hose out a little and beaded along the spot wear the hoses met in the end. I squished the hoses back together and put another bead down the end to seal it.
Does this sound like anything that anyone else had to do? (or the right thing to do in this situation???
