Mhh short shifter!
  • Mhh short shifter!
    also while i was working on things i mocked up the turbo mani on the new motor.
    mhhhh 1.8L of turbo goodness! yum!
    1992 Festiva... BP-T, Escort G5MR, no crossmember, aspire brakes, Megasquirt, Toyota COP's, coilovers and 6 puck SPEC clutch!
    Is that the same flange, or did you cut it and flip the flange? I thought you had the same manifold as mine.
      i thought i did but its unmodified so i take it no? i do however need to get the manifold modified from a t3 exh flange to a t4 exhaust flange
      my turbo is nice and big hehe, also got some 550cc injectors in the mail
        Mine points upwards, and is a t3/t4 flange. I also have a larger turbo for top end power :-) I look forward to seeing your build.
          What shifter is that and how much did it cost?
          93 GL modyfied!!!
          :fish:
            it was a 9$ shifter from ebay, cost me under 20$ shipped, wasnt the cheapest one though, its for a civic. ill psot a picture of what it looks like, its not a cheap flimsy welded together unit, its fully cast and should be able to take some abuse.
            note how the bottom is a casted in part on this unit, its identical to mine, on others there is a tube section welded to the bottom that the linkage bolts to, those have been notorious for breaking under hard shifts and are also cheaper, i decided to stay away ang get the 1 piece. once she is on the road ill give you some info on how well it holds up!
              I as well got a ebay short throw from a 88+ civic i believe. I know some people have run into issues with strength but mine has been holding up awesome. Mine was under 15 with shipping. It throws so nice but the only issue is how sloppy it is.
              88' Ford Festiva
              97' Chevy Silverado Z71
              94' Chevy S-10
                yeah i had to throw some washers and rubber o rings into mine to make her tight.
