Custom signals
Custom signals
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Brand enthusiasts are the root of all problems in the car community.Tags: None
Now that is cool !!------------------------------------------------
HD2500 Duramax Chevy
Z28 LS1 power 500 +
I had to pay a 109 dollar fine for having "white flashing lights"
I originally had the strobe in the reverse lens, I've moved it to the amber.
I also have a switch wired into a few dual position relays . . . switch off stock signals, switch on strobe signals. It involved running a new hot wire out to each of the turn signals for the control boxes, I then had to wire in another 2 position relay to send power through the flasher or straight to the controllers, Then to make the dash signals still work I wired each on its own relay, the flasher receives power even when the strobe circuit is energized, the wire that would normally turn the indicator on is now the coil control and the flasher is the source for the switch side, Took some sitting down with photo copys of the OEM schematic and a bottle of white out and some colored pens, many head aches and two revisions and I get a finished product utilizing 5 relays and a lit indicator switch, that is all hidden and looks completely factory ( accept for the indicator on the dash and if you were to pull the guage cluster and see the relays )
92 GL - parts car
Nice I like the rotaion effect you did there
92 GL - parts car
not hard to do I just drilled a 1/2" hole to accept the strobe light(has rubber stopper) and then wired in the control boxes
92 GL - parts car
What Pack said.
... once again with the egg mick, I warned you about that :lol:
