i ordered a 3 set comprising a volt, water temp, and oil pressure gague. They are mechanical gauges... and I would like to know where the sending unit is for the oil pressure is. If i'm not mistaken I will need a "T'' fitting. Can someone give me the location for the ''T''. Also where is the hookup for the water temp would be. Aprreciated.
Need a little help with my new gauges
Ok, you got me there - that did happen to me once. Thankfully, the gauges are mounted on piece of plexi mounted on the dash console, so the oil just pooled in the console and destroyed a road map.Originally posted by SimonTuffGuyReturn the mechanical gauge and get something electric... You do not want to run a tube that's going to be pumping oil inside your car (think of it breaking and what will happen)...
Will it happen? Maybe not... I wouldn't want to take the risk.
I'll keep a mechanical in mind when I replace it. What I'd really love to have is one that reads from 40-80psi (or thereabouts) rather than the 0-120psi that I've got. It frosts me that 80% of the gauge never gets used.
Yes, that's the sort of thing that bothers me.
B
