I installed a set of high power LED brake lights today (as pictured below) and these things are great. They're the first LEDs I've ever seen that are just as bright as regular bulbs. To install them, I had to make a very slight enlargement of the hole where the bulbs go into the tail light housings, but it was straightforward otherwise.
No point in showing a picture of them installed, because they look like regular bulbs when you turn them on. The difference is that they turn on REALLY fast, when compared to an incandescent bulb. When you get tailgated, that can make all the difference.
