Originally posted by Safety Guy
UPGRADE HEATER?
lol yeah and while your at it run your oil a quart high because that makes the motor run hotterOriginally posted by rotarykiddlow coolant works pretty good. :lol:
Seriously keep you fluids at the proper levels- Check your heater core [list:d338cc9755]for accumulation for foreign objects or dirt
Check your T-stat- make sure its the proper part number
Check your squirrel cage- mine was full of leaves when I got the car
Check your venting- make sure there's no holes or tears or kinks
Check your mode doors- make sure they turn when the lever is moved
- also make sure there's not a hole in your door [list:d338cc9755]mine had a hole in the vent mode door allowing cold air in from outside
After I had checked all of that my festy produces great heat, however if your in temps below 20 degrees you can add cardboard to the radiator make sure to leave 40% exposed to air though
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Poverty produces creativity
but im lookin
