Anybody ever tried to improve the heater/ fan? I've had 4 festivas and all of the heaters don't produce.....................much!!
UPGRADE HEATER?
Glad you asked!
I'm currently working on a woodburning stove upgrade as we speak.
Piezoelectric ignition, one into four "header style" smokestacks, custom paint job (moose and penguin scenery) and automatic ash ejection feature are some of the highlights!
I'm currently looking for a nice cordwood trailer to haul the fuel.
It'll be fantastic!
Have you looked at your heater core? it could be plugged causing a reduction in air flow. I know mine seems to blow pretty good when I have it on max, I have actually been using number 2 instead cause I find it blows more heat instead of acting as a cooling fan when the car is idling.Originally posted by stefanha ha
but seriously, a blower motor that could push air faster would be cool. I find mine on max is really weak.90 festiva BP/G25MR swap, spec v seats, aspire brakes, FMS springs, round headlight conversion with HID's, custom exhaust, fiberglass hood, and a whole lotta bodywork
BEFORE
AFTER
Someone needs to pioneer the hotrodding of Festiva heaters!!
I want a V-8 DOHC heater core with an oversized blower.
A person should also check their thermostat... There was a couple posts about it here not to long ago... Get the proper 2 stage one not the cheap single stage bulk parts store replacement....
Here read this...
BEFORE
AFTER
I had a festiva with the lame t-stat and it never hit the bottom (cold end) of the operating range. It ran cold all the time. When it was 15 degrees outside it would still roast me out. I've never had a festiva with a bad heater.youtube.com/neanderpaul 88 festiva LX w/BP G25 MR 5 speed waiting for wiring- 93 Festiva GL auto w/ air, waiting for B6t/G4A-HL - 98 Nissan Quest - 02 Mazda protege 5 wife's DD
Poverty produces creativity
