The wiring diagram for the remote progressive unlock worked perfectly.
For the moment, I have only wired the Mazda 4 terminal momentary switch for open only, until I can figure out a way to change a positive trigger switch into one that likes a negative trigger. I am going to have to open one up to see whats inside. I looked at the diagram for the Pride power antenna switch (page 52) because it looks identical to the Pride power window switches (page 56).
Doctor Livingstone I presume?
Has anyone ever seen a power door lock Pride? It's in the Electrical wiring Diagrams on page 54.
There is a Pride Door Lock Relay and Timer listed on Four Green, but no "Door Lock Main Switch". Unless Switch Assy Dr means door. For $3.67, it's worth a call to Ali at Four Green. I will buy it just to see what it is. I sure hope it's the three terminal switch I need.
