Hello all,
I recently installed a Pacesetter short shifter in my Festiva. Really liked the feel of it other that it seemed to be too far forward... in 2nd, 4th & reverse the shifter knob was about where neutral should be.
I solved the problem by shortening the shift rod by 1/4". Works great and the shifter knob now sits close to the stock position! I'm running with the shifter ball right in the middle of its adjustment range for know. I might try moving it a little higher to shorten the throw a little more.
Cheers
Cheers
