Pacesetter short shifter install tip
  • Pacesetter short shifter install tip
    Hello all,
    I recently installed a Pacesetter short shifter in my Festiva. Really liked the feel of it other that it seemed to be too far forward... in 2nd, 4th & reverse the shifter knob was about where neutral should be.
    I solved the problem by shortening the shift rod by 1/4". Works great and the shifter knob now sits close to the stock position! I'm running with the shifter ball right in the middle of its adjustment range for know. I might try moving it a little higher to shorten the throw a little more.
    Cheers
    Ian
    Sweet! Got any pics?
    -Scott
    Aqua 93 L
    Razor Red 09 F-150 XLT
    White 06 Ford Escape XLT
      I love my Pacesetter too. Had one in every one of my Festivas and it really helps make it feel "right" instead of like I'm shifting a Mac truck.
      Simon - pimptiva.com
        how much is this upgrade? my next stiva WILL be a 5 spd
        -Aspire brake swap COMPLETE!
          I think mine was under $100 when I ordered from the local auto store...
          You want to order the Pacesetter that fits the first generation Probes (which is 89 to 92 I believe)... That'll get you set.
            what modes need to be done to make it fit? or is it plug and play?
            92 GL - parts car
            97 aspire - parts car
            87 323 DX - daily driver
