I know he sold a coupple sets, who got the others? Has anyone tried installing them? I got a set and it seems the motor wont bolt up.
Power Windows From rolla
I got a set but have only used the armrest with switches,I already had Protege power window regulators in my car,I'll save them for when I need them.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
95 Taurus SHO auto 265hp
94 F150 351W auto (for sale)
95 Honda 1500 Goldwing SE
95 Iszuzu Trooper LS
What problem are you having? show pictures.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
I've had them in my car for 2 years now without any problems so I'll leave them in for now,will be easyer to find if broken.Renegade-Midwest Festiva Inc.Illinois Chapter
99 Dodge Caravan SE
My bad, they bolt up.. They use a different set of holes tho. I Didn't notice it because i had sound deadener covering the holes.. I'll grab pix this evening.
elcamino1, have you wired up the switches? did you use relays or did you run the current straight thru the switches?89SX funtop! Fully loaded!
RIP 90LX
Originally posted by stefan View PostMy bad, they bolt up.. They use a different set of holes tho. I Didn't notice it because i had sound deadener covering the holes.. I'll grab pix this evening.
stefan -
if you run your switches with full current that is alot of draw through them and they will get hot - thus shortening the life-span of them - I would use relays to control the windows you can put the relay in the door or under the dash or the hood like on modern cars.
From repairs I've seen on power windows its water damage to replace switches and use or a motor failure to replace relays.
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
if the switches have 18ga wire, and only 3 terminals, then they're designed to operate a relay. If they have 16ga or 14ga wire, and 5-6 terminals, they are designed to handle the current of the motor directly. Tpically, a switch like that can tolerate 30mps, and the motors typically draw 5-10amps. Relays may be unnecessary overkill, but do what you are most comfortable with.Jim DeAngelis
The switches are 6 terminal on the drivers side and 5 on the passenger side. I'd estimate that the wire is about 16ga (off the top of my head) I'd have to go look at the switches to be sure though.89SX funtop! Fully loaded!
RIP 90LX
