Tail Finisher
  • #16
    ^^^ you mean like this?
    Jim DeAngelis
    • #17
      Yeah just like that but my repairs on the TF are going to go a little more in depth!!
      • #18
        remember one thing though, if the tail finishers are 4-5 layers thick it'll weigh more which then the shock may start to not support the weight of the hatch when open
        just my 2 cents
        • #19
          ^^^ agreed. They need to be thin to limit weight.
          Jim DeAngelis
          • #20
            carbon fiber hoods are 5-7 layers thick....were talking about a piece 4 foot long by 16 inches thick. It wouldn't matter if it was 3 layers or 7...the hatch strut would still support it.
            Without further ado the fitment picture:
            First off we have the threaded stud that makes no contact anywhere on the panel but comes so inconviently close the the hatch handle you can't open your back hatch once installed.
            3 layers?? Maybe on the contours...
            Fitment of driverside above taillight
            The clip attaching the drivers side top of the ribbed TF...that's not gonna catch highway winds or anything...
            These next pictures are of the bow in the middle of the TF bottom center and the bottom overlap that probably broke david88 TF....notice that it is perfectly alligned in the bottom right corner...
            And the gap on the top...I tried to put my hand under it so you could she my hand through the crack...but wouldn't show up.
            My solution to fix all these problem is to put vasoline on my hatch nad make a backing plate contouring around where the lights go. I'm going to put holes to mount it in factory holes and use doublesided 3m tape all the way around sort of like the FMS rear upper spoilers.
            • #21
              I had the same fitment issues with mine. I pulled those thing little tabs off and took the bolt out of the center too...
              When I install it (or if at this point), it'll be molded in place.
              Simon - pimptiva.com
              • #22
                Bump! Just checking to see if anyones installed there's yet?
                Renegade-Midwest Festiva Inc.Illinois Chapter
                99 Dodge Caravan SE
                95 Taurus SHO auto 265hp
                94 F150 351W auto (for sale)
                95 Honda 1500 Goldwing SE
                95 Iszuzu Trooper LS
                • #23
                  At the risk of causing a Monsoon I too would like to see some detailed intalled photos... particularly of those that have been molded in.
                  Thanks
                  Ian
                  • #24
                    I'll go snap some pics here in a minute.....
                    Non mounted or moulded btw...
                    • #25
                      I'm done messing with it. PM me if you want to purchase it, in its current state.
                      • #26
                        Thanks for the phots. Does the black piece that covers the handle holds the license plate lights have to be removed or does the finisher fit over top?
                        Ian
                        • #27
                          Red is looking great Wes!! If it was smooth, I'd be interested in it.
                          -Josh R
                          • #28
                            Not a fan at all... but I appreciate you going to the trouble of sharing the picture. Knocks one more rare item off my "want" list.
                            1988 Chevy Sprint Turbo 997cc
                            • #29
                              I have a smooth one I might sell if the price is right
                              BPT, G5M-R, BP26 Exintake swap + Fidanza cam gear, NSRT4 FMIC + 2.5" piping, HKS SSQV BOV, Exedy clutch, 3" downpipe + 2" all the way back, Aspire brake swap, KYB GR-2 & FMS coil spring , FMS EURO body kit + Carbon fiber hood, Falcon RTX 15X6˝ + Toyo proxes T1R 195/45R15
                              • #30
                                What's that price?
                                -Greg
                                Redneck Engineer
                                FOTY - '09
