went to the junkyard looking for a mazda truck with clear turns but all had amber. I looked over and seen a Toyota Camery early 90's with clears and took the lens and the enitre unit off the car because they looked about the same size. Well if the didn't fit I would only be out a couple bucks.
under $10.00 mod
I went on and used the toyota turn signal assembly just cut my wires and rewired it up. Stopped at Lowes and picked up some nylon bushings 1/2inch to make them flush with the bumper and 2inch stainless screws to remount it. I could have put a thin bead of silicone around the lens and used the festiva turn signal assembly if I wanted but just went on and wired the toyota up. The holes actually line up.
I like the use of the nylon spacer instead of stacking washers
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Steve GT
