extra gauge lighting
here is a pic of LEDs installed - mine are blue of course and the tac and pilar guages are red LED
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
I think i may go with these:
do you think thats enough lighting?
-Aspire brake swap COMPLETE!
Originally posted by GenevaDirt View Postif you pull the light bar off there there is a piece of plexiglass that is colored...take it out...also I believe the non tach onse have the four bulbs....I put the ones from the non tach speedo in mine without the piece of glass....I have to keep it turned down on the lowest setting because it is so bright.
instead of start a new thread, i'll add to this.
I got a 9 LED strip that runs off of 12V. Now, as I have had my cluster out before, the stock lights (4 small bulbs) have 2 wires that are connected to the top of the guage cluster in the back with philips screws.
my question is, can i disconnect the 2 wires philips screws and remove my stock wires and bulb combo, and put my 12V LED's into that same 2 wire lead? or do i need to splice from a different location? i hope this makes sense.
as a follow up, at the top of the back of the instrument cluster, the 2 blub screws are "+ ILL" and "- ILL".. pretty straight forward.. i got my green LED strip installed this weekend, but i glued it too low as i can see the LED's when driving... i'll try to take some pics of when i 'redo' it to raise the strip up...
