Cluster Background
  • Cluster Background
    I can't find it on the site, but I know there is someone that can print off new backgrounds for the gauge cluster. I want to purchase one, or does anyone know of someone that can print off new backgrounds. Let me know. Thanks
    "If you're not first you're last!" -Ricky Bobby
    -91L "Oliver" Now B6DE swapped with an ATX Capri ECU on a MTX!!!!
    The little Festy that could...and did!
    (Gone on to a new life)
    -90 Ford Bronco II Eddie Bauer
    festiva tunner....I believe is the one that was messing with that recently
      PM Sent
      92 GL - parts car
      97 aspire - parts car
      87 323 DX - daily driver
        There were some samples in the gallery section but the links for them aren't working right now.
        Ian
          These are some that I made up but I can design it just about any way you like really.
          92 GL - parts car
            Those backgrounds are just way KOOL! I'd do a burn-out for a white background w/dark blue numbers & tic marks for a tach/speedo cluster! BOOHH-YAAH!
              what are the odds that some guys here can start changing speedo gears and we can start getting 120 mph cluster backgrounds?
              88 mustang 427 stroker garrett t-76 turbo best run 8.86@ 151.56
              91 red gl festiva the $50 daily driver <--toast
              WANTED 78-80 FORD FIESTA (PREF GHIA)
                feasibly possible.
                  Originally posted by festivaWES View Post
                  feasibly possible.
                  you change the gear I print the backgrounds? lol
                  92 GL - parts car
                    140MPH speedo from a '90-'94 protege (bp or b8) will fit the festiva orange clusters bolt-in, and the white clusters with a little work from a dremel (non-tach clusters only, don't think anyones tried this with a tach one yet) just need to use the faceplate from the protege to do a layout for the numbers for the new faceplate. If that helps
                    No festiva for me ATM...
                      What are the backgrounds made out of? Do they have an adhesive that they stick over the top off what you have or is it a piece that you swap?
                      ROBc
                        they way I make them is on high quality photo paper and I cut all the holes for the screws and idiot lights and needles. you would have to take the clear plastic off, then the guage needles, then install the new background under the screws that hold your guages down.
                        92 GL - parts car
                          I have the 110mph speedo and tach from a Kia Pride
                          Chuck
                          91 GL -Ol' Rusty
                          93 GL - Lil Red
                          91 L - Tweetystiva
