I can't find it on the site, but I know there is someone that can print off new backgrounds for the gauge cluster. I want to purchase one, or does anyone know of someone that can print off new backgrounds. Let me know. Thanks
Cluster Background
festiva tunner....I believe is the one that was messing with that recently"FLTG4LIFE" @FINALLEVEL , "PBH"
PM Sent
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
There were some samples in the gallery section but the links for them aren't working right now.Ian
These are some that I made up but I can design it just about any way you like really.
92 GL - parts car
Those backgrounds are just way KOOL! I'd do a burn-out for a white background w/dark blue numbers & tic marks for a tach/speedo cluster! BOOHH-YAAH!
what are the odds that some guys here can start changing speedo gears and we can start getting 120 mph cluster backgrounds?88 mustang 427 stroker garrett t-76 turbo best run 8.86@ 151.56
91 red gl festiva the $50 daily driver <--toast
WANTED 78-80 FORD FIESTA (PREF GHIA)
92 GL - parts car
140MPH speedo from a '90-'94 protege (bp or b8) will fit the festiva orange clusters bolt-in, and the white clusters with a little work from a dremel (non-tach clusters only, don't think anyones tried this with a tach one yet) just need to use the faceplate from the protege to do a layout for the numbers for the new faceplate.If that helps
No festiva for me ATM...
Originally posted by rcottle View PostWhat are the backgrounds made out of? Do they have an adhesive that they stick over the top off what you have or is it a piece that you swap?Last edited by Festiva_tunner; 01-29-2009, 05:35 PM.
92 GL - parts car
Originally posted by Festiva_tunner View Postyou change the gear I print the backgrounds? lolChuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
