Okay, so figured out that most of the side molding pieces on the new one need to be re-glued. Except for the short pieces on the front fenders, all were either gone, or loose enough they need to be re-applied. Going to be painting shortly, so I just pulled them all off. Anyone have any tips/tricks to getting the glue off the car. The top/bottom foamy pieces are cake, it's the big spooge of glue down the center that's kicking my butt right now. And ideas? That won't do too much damage to the car itself. Thanks in advance.
Side Molding Removal Tips?
I took an old credit card and sharpened the edge by rubbing it on the garage floor, then used it like a knife to slice the glue off (in a sawing motion while pulling up the free edge of glue with my other hand). It worked well enough to where I just had a little residue left and then used pb blaster and a rag to rub the rest off"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
goo gone
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
I Just removed mine. Used Body trim adhesive remover and a piece of nylon like material for a scraper. The adhesive remover contains Xylene. Best use it outdoors. Goo Gone probably just as good. I first started with a metal putty knife. Trust me. DON'T use a metal blade. I made a mess of the paint and primer on the left door. Added more work. Patience, patience, patience.
Yeah don't use a blade. I forked up my paint with gouges too. IDK why I didn't think to use WD-40 + elbow grease + nylon scraper, which removes glue.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Not overly worried about a little paint scuffage, as she'll be getting the rustoleum paint job if it ever quits raining. Been thinking I may just leave it alone anyway. Figure on putting the trim pieces back on when she's done. Just figured if that glue was easily removable, I'd go without the trim for a bit, just to see if I liked the no-trim look better. May hit it with some goo-gone, and a scraper tomorrow, and see what happens.
1989 L - 247K miles Slick
I think the trim-free look depends both on personal taste and the color of the car. My dark blue one is going to get a silver pinstripe. To put trim on it will clutter up the looks, to me.Originally posted by batstiva View PostNot overly worried about a little paint scuffage, as she'll be getting the rustoleum paint job if it ever quits raining. Been thinking I may just leave it alone anyway. Figure on putting the trim pieces back on when she's done. Just figured if that glue was easily removable, I'd go without the trim for a bit, just to see if I liked the no-trim look better. May hit it with some goo-gone, and a scraper tomorrow, and see what happens.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The only reaon i said to take a blade to it is because he said it was going to be painted...
I have a rubber eraser wheel off of the mac tool truck that removes all of that junk glue with no chemicals needed at all.Last edited by festivaWES; 08-01-2009, 02:18 PM.---------------------------------------------------
Mine, at most, is only going to have the door trims, and the hockey stick decal, the way it came from the factory. Think I'm going to leave the glue alone, and just put the trim pieces back on after paint.Originally posted by TominMO View PostI think the trim-free look depends both on personal taste and the color of the car. My dark blue one is going to get a silver pinstripe. To put trim on it will clutter up the looks, to me.
Clean it off....it won't lay right if you re-glue over a uneven surface....
If you have acess to a air compressor I'll ship you my adhesive/pinstriping remover tool. Pm me.Last edited by festivaWES; 08-01-2009, 05:43 PM.---------------------------------------------------
Right you are sir, it'll have to come off one way or the other. And no, I don't have access to a compressor. Just have to do it the slow way. Been hitting it with pb since yesterday, and it is getting somewhat easier to get off.Originally posted by festivaWES View PostClean it off....it won't lay right if you re-glue over a uneven surface....
I've used the destriping/eraser wheel too; worked well on some things like the dealer logo on the rear hatch, and some of the pinstriping. But there was a big piece of striping above the rubber door guard that the wheel wouldn't get all the glue off. I shoulda used PB or WD-40 to finish the job, but used a razor blade instead, which I regretted.Originally posted by festivaWES View PostI have a rubber eraser wheel off of the mac tool truck that removes all of that junk glue with no chemicals needed at all.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Whats the name of this tool? Is it just something that attaches to a grinder? Can you get it at your local autoparts store?Originally posted by festivaWES View PostIf you have acess to a air compressor I'll ship you my adhesive/pinstriping remover tool.Search Master - Honorary Member of Midwest Festiva Inc., Gulf Coast Chapter
- Unknown
- Quentin Crisp
- Bumper Sticker
