It's basically a straight air grinder with special rubber wheels. The air grinder has a limited RPM setting so you don't burnpaint up from the friction involved. I doubt you can get it at the McAuto parts stores..
Side Molding Removal Tips?
I had a pretty old sticker on the back of my window and i took a razor and scraped it off but the adhesive glue was stuck onto the glass. "Goo Gone" took it right off. it's only a couple of bucks at Walmart. you wouldn't even know there was a huge sticker on the back of mine. Hope i helped!Amazing Amanda
^^ Ha ha, love the sig.
Stickers and decals came off pretty easily. Goo Gone is great stuff. Somewhere along the line, someone laid down a line of solid black glue.(factory??) Probably 3/4 inch wide and between 1/8 and 1/4 inch thick. Nearly got one side done now. Won't even tell you how we got the DOT stickers of the trucks at the cable company I used to work for. :shock:
1989 L - 247K miles Slick
It's a destriping wheel, made of rubber, that fits onto any drill. At stores that sell to body shops, and maybe some McParts places. Mine cost $15 and well worth it.Originally posted by MONSOON View PostWhats the name of this tool? Is it just something that attaches to a grinder? Can you get it at your local autoparts store?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Okay, well now I feel like an idiot. My solution was laying on top of my computer desk the whole time. A piece of nylon/kevlar pull string from a copper jacketed fiber optic cable. Figured if it was strong enough to split the outer coating, and the copper jacket on a fiber cable, it could handle that glue. Took a piece about 2 feet long, got the edge of the glue loose, and used the pull string like a cord saw. Took me big chunks of 2 days to do the driver's side door + the short piece in front of the door. Just went out and finished the driver's side, and halfway down the passenger side in about 30 minutes.
its called eurathane...and it's factory!Originally posted by batstiva View Post^^ Ha ha, love the sig.
Stickers and decals came off pretty easily. Goo Gone is great stuff. Somewhere along the line, someone laid down a line of solid black glue.(factory??) Probably 3/4 inch wide and between 1/8 and 1/4 inch thick. Nearly got one side done now. Won't even tell you how we got the DOT stickers of the trucks at the cable company I used to work for. :shock:---------------------------------------------------
^^ Wasn't sure. First set of trim pieces I've actually pulled all the way off. Either way, it'll be done the next time I get about an hour to work on it.
