so im better off with the protege's then
ok protege cluster question
You will need to use the needle from the Protege spedo for some reason (at least On Mine the shafts for the needle were not the same size) You will need to use the gears as well - on mine I simply dissassembled the Odometer assembly and removed the bracket for the button because I didnt want to modify the cluster that much.
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Yes it does just if yours is the white lettering you have to trim the plastic to fit the speedo end, but if it is orange you shouldn't have to mod the plastic. You have to get a custom face plate or some how mate the two together. That is what i am doing. There is only one in the jy i go to.
I could send you one at cost if you need one.Originally posted by hofficergrover View PostYes it does just if yours is the white lettering you have to trim the plastic to fit the speedo end, but if it is orange you shouldn't have to mod the plastic. You have to get a custom face plate or some how mate the two together. That is what i am doing. There is only one in the jy i go to.
Do I need to pull the whole cluster or just the speedo??
:festiva::newb::festiva:
Originally posted by Claude View Postim interested..does it work with the stock festy instrument panel?
Yes it will work with the stock cluster
It's Easier to pull the whole cluster - easier to ship just teh guage and faceplateOriginally posted by wrongfulleaf View PostI could send you one at cost if you need one.
92 GL - parts car
Thats a RX-7 Deep Set Drifting Wheel - I've pulled the fake leather off and removed the left over adhesive though. The onlt issue I have with it because I'm so tall I dont see the numbers 60-80 with out looking under the wheel. Its noticeably smaller than the stock wheel but I love it.
92 GL - parts car
