C pillar bar source
C pillar bar source
Gone but never forgotten, "Hulkstiva"...http://www.fordfestiva.com/forums/sh...ht=progressionTags: None
What is a C pillar bar and what does it do?Dan
Dang, I thought it might be like a shock tower bar for the rear!
Always called those clothes bars.Dan
Cancel that c pillar bar fitting....it gets in the way of the hatch strut!! Ooops! Guess you could still use it if you really wanted to though. It fits the strut towers too, so you could put it there if you wantedLast edited by lanemeyer14; 01-13-2010, 06:19 PM."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
sweet i thought it would fit i will make a bracket to make it clear the hatch. shouldn't be to hard to do, but i want mine to be a little higher up. also what is it hitting?
and thanks for the heads up.Last edited by hofficergrover; 01-13-2010, 07:11 PM.
doesn't that limit your rear cargo capacity? haha.. that is sweet. anxious to see if there is a difference in handling.
-Aspire brake swap COMPLETE!
The strut that holds the hatch up hits the bar when you try to close the hatch. You would have to take that strut out if you wanna use the c pillar bar in that position. If you want to mount yours higher you will have to drill and tap new holes. I just installed it in the existing seat belt holesOriginally posted by hofficergrover View Postsweet i thought it would fit i will make a bracket to make it clear the hatch. shouldn't be to hard to do, but i want mine to be a little higher up. also what is it hitting?
and thanks for the heads up."Lane, I've been going to this high school for seven and a half years. I'm no dummy."
So you're saying it will fit onto the top of the rear shock mount, so it would go across to the other side to connect the two shock towers? Just like a strut brace for the front?Originally posted by lanemeyer14 View PostCancel that c pillar bar fitting....it gets in the way of the hatch strut!! Ooops! Guess you could still use it if you really wanted to though. It fits the strut towers too, so you could put it there if you wanted-93' L BP swap/e-series, coilovers, RIO front swap, redrilled festy drums, Miata 14" 7 spokes.
-85' Nissan Sentra 5 spd.
Yep, fits there too. I put it on but didn't bolt it down. BTW, these bars can be had on ebay for like $15-25 shipped, so it's a fairly cheap mod!Originally posted by Festiva_Fred View PostSo you're saying it will fit onto the top of the rear shock mount, so it would go across to the other side to connect the two shock towers? Just like a strut brace for the front?"Lane, I've been going to this high school for seven and a half years. I'm no dummy."
yeah i got my front bar for 26 shipped and the rear 30 bucks both same brand. i will be making another bracket the mounts the bar to the strut as well as the body for extra strength. i would say to do this as well, but i don't know if it is really improving any thing tho.
also i think if you find a smaller strut for the hatch you can remount it and still have a strut.Last edited by hofficergrover; 01-13-2010, 07:55 PM.
can you try it behind the seat (where there is a threaded hole) to put a 4pts harnessLast edited by Maxtiva; 01-13-2010, 08:15 PM.
Definitley going to get one of these for myself sometime! Thanks for discovering this!!
