escort map light
    Reverse the wires.
    -Greg
    Redneck Engineer
    FOTY - '09
      Originally posted by wrongfulleaf View Post
      Well my mini tape must have fallen into one of the cracks or I left it at the shop. I can give you a for sure measurement tomorrow but it isn't any farther than 5 inches but more like 4.
      its really tight, im thinking maybe i could just get a flat plate of steel, drill the holes to match the roof and drill 3 more a little back and mount it?
      Right now there is about 2-3 inches from the factory light to sunroof
        Euro i have the wires right. The car is not getting any juice to the light. So i have a wiring problem with the car it's self.
          Make sure your switches in the door jams are making a good contact.
          93 GL modyfied!!!
          :fish:
            I will have to check them i didn't before.
            Thanks
              Messed with the door switches and nothing so i rewired it strait to the battery and grounded it and works great.
                Did you check the fuse?
                Dan
                  no is it in with the seat belts like the horn and tail lights? If so i took that fuse out. lol
                  • #24
                    In the fuse block in dash.
                    Dan
                    • #25
                      Yeah what i ment the horn fuse is the fuse for the break lights. So would the automatic belt fuse be with the same fuse?
                      • #26
                        The escort map light does not clear a factory sunroof, i've tried before
                        • #27
                          thanks for the clarification, im still thinking maybe i could move it back some with a plate....we will see
