I just open and close mine without the key, the junk on our cars is so flimsy. Now with gas prices climbing again I'm starting to worry about a vulnerable gas cap (hoping someone stealing gas doesnt know the uses of a 14mm to do so). I got the lever/cable assy. from a merc tracer. Looks like a simple installation.
Gas Door Popper
I have to do this. It's the perfect solution for opening the door after the lock is shaved off.Festiva: Because even my dog can build a Honda.
Any 323 (Or Protege maybe?) with a trunk should do. IIRC John got his out of a Protege.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
ok, the popper for the trunk, does it actually pop the trunk or does it just unlock it?
Depends where you mount it. mine would pop the hatch reguardless if its locked - however I noticed on the stock latch there is a provision for a unlock clipOriginally posted by timmay89 View Postok, the popper for the trunk, does it actually pop the trunk or does it just unlock it?
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
Allow me to fix your post for you.Originally posted by magistratemg View Posthere's an idea:
http://www.cardomain.com/ride/2253160/7
Originally posted by magistratemg View Posthere's a good idea:
http://www.cardomain.com/ride/2253160/7Festiva: Because even my dog can build a Honda.
Tom (tomino) doesn't know it yet but i borrowed a small magnet from his car at gregs (eurotiva) and it holds my door closed great! i just put it where it hits the mount on the door and it opens and closes by pushing on the back of the door... I shaved the lock of course but couldn't you leave it open? Or would the key not come out if it is open? There is no handle so if somebody went to open it without knowing they would think there was a latch inside..1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Originally posted by eurotiva View PostJust lube it.
To quote the Mythbusters, "When in doubt, lubricate!"
Lube it X2!Contact me for information about Festiva Madness!
Uh, those where my magnets, so Tom could remove the crud in his 323's cooling system.Originally posted by Flyin4stroke View PostTom (tomino) doesn't know it yet but i borrowed a small magnet from his car at gregs (eurotiva) and it holds my door closed great! i just put it where it hits the mount on the door and it opens and closes by pushing on the back of the door... I shaved the lock of course but couldn't you leave it open? Or would the key not come out if it is open? There is no handle so if somebody went to open it without knowing they would think there was a latch inside..
The crud happened to be magnetic and those high strength magnets would have helped clean the cooling system.
But, if you've put one to good use then that's enough for me.
Ya, I believe that any system would work, but obtaining one out of a 323 might bolt in better.
