Originally posted by Nickb1907
Collapsible mirrors
^^^ Those are Protege' mirrorsOriginally posted by freshtiva View Post
Dan
Pair of mirrors I removed from a Mazda Protege'
Can do. What are "tabbed mirror motor housings" exactly. There are quite a few Protege's around here. Wish there were that many Festiva's around. I actually like the Festiva mirrors better, as they are slightly smaller. Since I cant find any, I am going with the Protege mirrors. I plan on forming the leading edge to fit the window curve too. Will have to fill edge with JB Weld to keep it smooth and factory looking.Dan
Originally posted by drddan View PostCan do. What are "tabbed mirror motor housings" exactly. There are quite a few Protege's around here. Wish there were that many Festiva's around. I actually like the Festiva mirrors better, as they are slightly smaller. Since I cant find any, I am going with the Protege mirrors. I plan on forming the leading edge to fit the window curve too. Will have to fill edge with JB Weld to keep it smooth and factory looking.
Read through this to see the tabs and how to remove the inners of the mirrors
92 GL - parts car
97 aspire - parts car
87 323 DX - daily driver
plastic with tabs
I only want the plastic half of the motor housing that has the tabs or ears.
When you peek in to the protege mirrors. Check that both ears are intact. If so, just revove the screw out of the bottom drain hole, carefully lift the ears off of the inner diecasting where it is hanging, cut the wires with a pair of pliers, pull the mirror straight off from the motors, take out the pin on the back and the three screws that holds the two halfs together, throw out the mirror and the motors and I will pay you for the half with both tabs (ears). I've got the operation down to about 3 minutes per mirror.
It is the ears that break off due to narrow cross-section. Out of about 40 Proteges, I only found 1 left and three rights that had both ears intact.Last edited by bravekozak; 04-02-2010, 05:46 PM.
Gotcha.^ Those are some really small tabs. Now I gotta look at mine and see what is in there.Dan
Ive been working the rotating shift for over two years. One week its 7am-3pm, next week its 3pm-11pm. Last week it went from 3-11pm to 3am -3pm. Two days after I was going to bed at 1am now Im getting up a 1am and working a 12 hour shift. Body cant adjust that fast. Next week back to 7am-3pm. :sad1::confused2:Originally posted by MONSOON View PostWait til the days just bleed together Marcus. Thats real fun. I just came off of working between days and nights with a day in between to adjust. Had been doing it since January. That was lots of fun.sigpic
Also good for gaining enough space to walk between cars in the garage without bumping the mirrors.sigpic
Ears ? Not sure what you mean.sigpic
What about fixing the tabs? I looked at my Protege mirrors, and the drivers side mirror had a broken tab on the housing. I fixed it with a small strip of aluminum and 5 minute epoxy. My computer is down (i'm writing from work) and I cant get to my photo's, or I would supply a pic. Basically I bent a piece of alum. to make a new ear with slot, cleaned, sanded the alum. and the plastic, cleaned again, glued the alum strip to housing and its stronger than original ear tabs. If you want pics, I will try to get some.Originally posted by bravekozak View PostThis is what I am looking for. As many as you can find with both ears intact.
There are LH and RH parts. Thanks.
http://bwbronze.com/festiva/pmm_cover.jpgDan
^ that would work well one would think - may be the solution to my swoopies broken tabs
92 GL - parts car
