OK, so the stock festy horn is sweet when you want to let the Hummer know that you are passing them in the snow, but when people cut you off just b/c your little it would be nice to make em wet their pants....
So I searched all around the forum and old boards and even checked out the manual to see if I could find a wiring diagram for the horn, but no luck. See the problem is, i don't want to replace the stock horn, I want to add a second horn w/ a toggle switch under the dash {no, not an air horn tho I would luv that! just a deep louder fairly cheap one (recommendations welcome)}
Would I have to get a second relay and run a whole new system, is this just not practical, or can i get by some how else?
Thanks!!
Thanks!!
