Power Rear Windows
    2 Caravans
    I have two Caravans and I always play with the power rear windows. I will measure how far both the Festiva and the Caravan windows move tomorrow in the daylight and report back.
      Originally posted by wybnrml View Post
      IIRC Ford Windstars only have one switch for the rear wing windows.
      nope, they have two.
      1993 Festiva L, aspire swapped, selling parts for a BP+T build.
        correct...I have 2 sets.....lol
          I checked the ones on The Montana and they open the same distance as the Festiva's. Now i need to find a set. Off to the junkyard tomorrow morning!
            That's interesting about the Montana ones, because I'm fairly certain the Caravan ones do not open as wide as the Festiva rears open. I imagine that a person could mod the mechanism, but it would definitely be easier to have the ones that open the same amount to begin with.
            1988 L - 232K miles Batstiva
            1989 L - 247K miles Slick
              Chrysler town & countrys have them also
                Chrysler openers
                Chrysler openers Town and Country, Dodge Caravan, Plymouth Voyager are all identical. They will not work because they require a perpendicular mount.
                The Festiva C-pillar has a very sharp angle. Besides, the Festiva opens only 1.343" and the Chrysler vans open 1.834" at the push point.
                Let's keep looking.
                  Ahh, but that's with the stock hinge attached.
                  With the hinge disconnected, the window will open well beyond the 1.8" that the electric actuator will try to push. I just opened mine past 4", so actuator travel is not an issue. Mounting the actuator to the frame, well we'll sort that one out later when Pull-A-Part opens.
                  John
                  91L 5-speed, RIP
                  89L 4-speed, teal/white
                  http://johnriederer.blogspot.com
                  • #24
                    I would steer clear of trail blazers or caravans unless you plan on remote mounting the motors - I looked into this a could years ago when I had both at my disposal the rear pillars on them are larger and they have a air gap between the pillar and the trim equating to more space to hide the motor
                    Older town and countrys may work though our voyager had manual windows so I could never check
                    But with the effort you could create a linkage like the window regulators use and mount the motor in the space above the tail light the windows will open beyond four inches with out the latch installed
                    92 GL - parts car
                    97 aspire - parts car
                    87 323 DX - daily driver
                    • #25
                      the best motors for rear windows i've seen and i might try is the ford windstar rear window glass setup i was doing some research and i might try it out i have some spare parts from my dad van and i'm gona try it out
                      • #26
                        i got motors out of a 95 Nissan Quest and 3 hatch lock actuators (for power locks) from the Quest, and a 93 & 95 Mercury Villager. those parts all look similar in all 3 vans. i don't know if i can get the motors to mount but i will sure try!
                        • #27
                          my motors dont even come close to bolting up, thanks to the pillar angle. i guess they are going on ebay
                          • #28
                            I have a feeling the actuators off a '78-'82 Chev Malibu 4 door might work. The windows in the back doors don't roll down, so the tiny triangular windows behind them open up outward instead and a few had power. I know because I had them on mine. And they're in a pretty tight space in the original application so they've got a better chance than minivan ones do.
                            Only problem is, good luck finding one. A lot of them didn't even get the triangle windows, much less powered ones.
                            • #29
                              I installed them
                              I took them out of a Cutlass Supreme at a junkyard and installed them in my 81 Iraqui Malibu. They did not push out, only turned the little quarter window in the rear. The motors are ugly and had to be hidden inside the rear doors.
                              The switches were located on the rear doors.
                              • #30
                                Crazy thought on the way home..
                                What does a '91-'96 Mazda MPV have in the back of it? Does it have powered back window vents? Just thinking that with all the other parts that seem to be shared, an MPV or maybe even an Aerostar might be a candidate..
                                Carz:
                                '09 Ford F-150
                                '80 Chrysler LeBaron Town and Country
                                '80 Volvo 240 2dr coupe
                                '93 Festiva GL
                                225996.9 kilometers = 140428.0 miles on the odometer
                                ...and definitely more soon..
