My passenger side manual belt I have only goes out about 1/2'' at a time and then clicks any ideas on how to fix this. Also would using the manual seat belt receptacle from the donor car be advised or are the lap belt ones for the auto belts fine? It seems like the manual belt receptacle has more of a robust mount than the auto one.
manual belt swap help needed
Uhhh when I tried the belts out of the Capri the passenger one would lock up so bad it was impossible to use. Make sure the big thing the belt comes out of is as straight and vertical as possible.91GL BP/F3A with boost
yeah I didn't put it in the car yet so that might be part of the problem. My friend said there is an inertial switch inside.Last edited by big_ty2003; 06-13-2010, 10:54 AM.
Poverty produces creativity
