I haven't been on the forums much lately, but for good reason. I've been making pretty steady progress on my Festy.
Clicky
That's acrylic. I'll be coating it with VHT taillight blackout crap and mounting indicators behind. I bought way too much acrylic so if anyone wants to do the same fire me a PM and I'll make another.
And all 4 VW wheels are on now. Will strip, polish and re-clear them eventually. As well, I cut the aspire bump stop so both the festy and aspire stops fit the strut. Can you say stiff? Unfortunately the Matrix sway bar I mentioned earluer won't fit an aspire rear like it does the festy rear without some modification. That doesn't mean I gave up on it but I have other stages of the project to worry about.
Piccy
And finally, I put 7" rounds in from a 79-84 Toyota Truck in there. They bolt up easier than the VW buckets, you only have to drill one hole at the bottom. And with slight modification they can even bolt up to that brace that goes from the corner light to the stock headlight.
Linky
And the stock grille is not going back in. I'm toying with ideas for a custom replacement.
Clicky
Piccy
Linky
i want to get the same speedo gauge in my car...
