Clever aspire tach install locations?
  • Clever aspire tach install locations?
    I can't for the life of me find an aspire tach cluster....so I'll go aftermarket.
    I don't want a 6" tach on my dash (bad enough I have the manifold vacuum gauge up there).
    So, any good places to install a 3" or 2 1/16" or whatever gauge?
    www.dantheoilman.com
    Go ahead and ask me why
    Would the 2 1/16 tach fit in a gauge pod on the windshield piller? Or a 3" on the steering column
    93 GL modyfied!!!
    :fish:
      I had a 3" SunTune tach on the column of my 94 Assfire. 2 sheetmetal screws, tach positioned at the 2 o'clock on the column plastic.
      Jim DeAngelis
      kittens give Morbo gas!!
        Tach location
        I have mine mounted on the black plastic surround that is in front of the cluster. to the extreme left. I does block my view of the idiot lights in the cluster but it looks damn good and the wires are totally hidden.
        1996 Aspire, 2DR 5SPD 185 60 14, Aluminum rims, Mild Stereo system, some neon tubes, 185 000 km not a speck of rust runs like a champ
        B8-ME Swap COMPLETED.
          try car-part.com there are a few tach clusters on there. just a word of advice, bite the bullet and call the number, parts yards NEVER check their e-mail.
            Already thought of that.
            Didn't seen any on there that said they had tachs.
              I called a couple places and they don't have them. The one that did for $50 had already crushed the car with the cluster in it... darn. It's actually cheaper to get a $30 tach than try to find a SE cluster. I got the mini sunpro from Autozone, it's a little hard to see actually but it will keep me from overdoing it.. at least. I put the tach on the right hand side corner of the steering column, should have put it over further it blocks the temp gauge.
              91 rusty Festiva 260k
